- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi all,
I am fairly new to AutoCAD 2019. Currently, I am experiencing an issue with finding BOM panel. As per other POSTS/Solutions. I went to Annotate and right clicked to make sure all panels that are available visible, but BOM panel is NOT even on the list. I only have a table option available to me. Please advise if there is a setting I am missing or this is an external ADD ON that I will need to obtain. Thanks!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
For extract datas to tables or excel:
https://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-5A39FFE8-10AC-4AE5-8EF4-D097C8261D1A
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank for the reply. 1) I understand that I can create Table and manually manage it. 2) I was really looking into BOM since that does most the work from what I saw. 3) To clarify the answer to make sure I understood this properly AutoCAD 2019 doesn't have BOM unless it's mechanical. However here is my confusion https://www.autodesk.com/products/autocad/included-toolsets. It specifies as mechanical tool set is included or am I missing something? And if it is included how do I obtain it?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Mechanical is another product, if it is available for using is depends on your license.
https://forums.autodesk.com/t5/autocad-forum/specialized-tool-sets/td-p/7987719
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks! I assumed it was something that I had to install. I followed "https://forums.autodesk.com/t5/installation-licensing/one-autocad-2019-release/td-p/7875496" I will download it and install hopefully everything will work now.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @User__CAD,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I'm glad to see that @cadffm was able to help you with this question. He is correct that AutoCAD Mechanical contains such a feature and can be found in your Autodesk Desktop App or in your account page if you are on subscription for One AutoCAD or perhaps the AEC Collection.
Please return if you need additional help on this.
John Vellek
