ChicagoLooper
en respuesta a: Anonymous
You should re-insert the points.
There are two red flags fluttering violently in the wind.
  1. Your units are feet and inches and although it can be done, it is not considered to be 'best practice' when you want to extract coordinates. Put the units in all feet or all inches, not a mixture of both. Feet with two significant digits would work fine for you, e.g. 6.5' equals 6'-6", 12.25' equals 12'-3" etc.
  2. Your coordinate system is not in WCS. The current UCS is unnamed. This could mean you have some points referenced to one 0,0 and some points referenced to another. There is no telling if you used a third 0,0 point when inserting the points, but that possibility does exist. When you extract the coordinates, they will be messed up and it'll be much easier to re-insert the points. once you have completed inserting the points, extracting the coordinates will be easy.
Chicagolooper
