640 Vistas, 4 Respuestas
Creating an external table with correct UCS coordinates for blocks
Greetings to all,
After not succeeding, I decided to come here for help with a fairly silly think I'm trying to do: I have a drawing filled with blocks, each one tagged with a number (its the same block, all differentiated by the number contained in the tag), and now I need a table containing those numbers and the xy coordinates for each.
Ive tryed using dataextraction but noticed one major issue:
These blocks were input into the drawing in batches, and as I was inputing these, I kept changing the UCS. After inputing everything, I have now set a new UCS that I want to call my 0-0 point - and thats the point I want the table to relate to. However, as Im trying to export the data, I have realized the coords there are not respecting the now newly UCS set for the file - instead of that, I'm getting numbers related to those past multiple UCS I used while drawing those block batches.
Is there a way for me to export a table at this point listing me the block tags (numbers) and their current position in relation to the current single UCS set for the file?
I'd appreciate any help at this point and have also added the file for checking!
Thanks in advance,
Joao
