09-23-2018
01:42 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-23-2018
01:42 PM
I agree with @neaton that you need different viewports.
If necessary, the two viewports can overlap or be stacked so you can see both shaded and hidden objects.
"Hide" objects and "wire frame" objects should be on separate layers.
Set the visual style and layer visibility of each view port.
Adjust the draw order of the viewports.
Tips:
- Aligning viewports is difficult. It is easiest to create a viewport, adjust the view, scale and layers. Then copy the viewport to the same location.
- Then adjust the layers of the second viewport.
- Lock the viewports.
- Save layer states for the "Hide" and "Wire frame" viewports.
- It can be difficult to select the "bottom" viewport; carefully dragging the corners of the upper viewport inward will make selecting the lower viewport easier.
- If the viewports get out of alignment, it is easiest to delete one of the viewports, copy the other, then apply the apply the correct label state.
Christopher Stevens
