2880 Vistas, 4 Respuestas
TEXT HEIGHT CAN'T BE CHANGED TO SMALLER THAN 1/4" already check STYLE
Hi everyone,
I am using Autocad 2015. I tried to reduce text height to 1/8" (in both dim and text style) , but it's always back to 1/4" as smallest size. I checked STYLE dialogue, text height was set at 0. I tried to change precision factor in Dim to 1/32", but text height still couldn't go smaller than 1/4"
Anyone can help would be appreciated!
Moshe-A
en respuesta a: Anonymous
hi,
try this: create a new text style with 0 height and change the text style of the dim style - does that solve the problem?
moshe
j.palmeL29YX
Please post an example drawing here so we can reproduce the behavior.
And tell us exactly what you want to do.
cadder
Jürgen Palme
Alfred.NESWADBA
please start command _UNITS and allow a higher precision ...
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
Thank you million Alfred!
The precision in Unit dialogue determines minimum value of text height as well as dimension text.
