en respuesta a: cadffm
So, I am not totally comprehending the difference between the block definition and reference, in regards to transferring it to you to look at, but I was also having problems with another block with the same name. I did a "Write Block" and renamed it(after using BATTORDER on the attributes, in the block editor-thanks CADffm & John.Vellek) and this worked.
I'm not really sure when to use ATTSYNC though. After editing the block and when it is inserted into a drawing?
Thanks so much for your help, both of you!
Michael
