cadffm
en respuesta a: Anonymous
I now have your block definition (but not your block reference)
but along with your last answer, I'm sure: Attsync was the solution, right?
In short:
ATTDEF (non-conatant) are only the template for new blockreference-attributes,
after creating the blockreference the attributes of this blockreference are absolutly independing from your
block(definition) / With one exception: The position - but only if you use the property 'lock position'.
You can delete all your attdefs from your block, but you will see and can edit the attributes on your existing blockreferences as well.
ATTSYNC delete, create and edit attributes of existing blockreferences of your block, so they are 99%* even with the current blockdefinition.
*this is a sidekick to AutoDesk, because not all properties of attributes are really sync with the current definition.
Nice if it helped.
Sebastian
