- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Ordering Attributes in Block Attribute Manager
I am having issues with getting the attributes to show up in the right order in the Enhanced Attribute Editor. I did the painful task of re-ordering each of the 50 attributes in the Block Attribute Manager(shown below), but when I double click the block to edit each attribute, which opens the Enhance Attribute Editor, they are in reverse order. This is also the case when inserting the dynamic block, when prompted to enter values for each attribute. you have to start at the last row in the table.
Attached is the block for further inspection.
***(Side problem, discovered while attaching the file: I'm having a hard time having the preferred visibility state show up as the default. I want all rows of the table to show up and be editable when inserting the block)***
***EDIT*** I went ahead and added a visibility state "All" at the beginning of the list, which seems to sort of fix this additional problem, but now I am showing that the block inserts with missing borders to the table. Attached is the updated block. I will keep working on it from here.
Thanks for any help offered!
Michael
