1868 Vistas, 1 Respuesta
ORTHOMODE
ORTHOMODE
ORTHOMODE IS USED TO DRAW A LINE HORIZONTAL OR VERTICAL.
IT'S A TYPE OF OPTION IN AUTOCAD WHICH CAN USE TO DRAW A STRAIGHT LINE WITHOUT ANY MISTAKE . LINE CAN BE HORIZONTAL OR VERTICAL. THIS OPTION REDUCE THE MARGIN OF ERROR WHILE DRAW A STRAIGHT LINE.
HOW TO ON/OFF ORTHOMODE (THE OPTION)
THERE IS SEVERAL WAY TO ON/OFF THIS OPTION WHEN WE USE AUTOCAD, WHICH ARE FOLLOWING:-
1.BY KEYBOARD:-
THERE IS TWO WAYS TO ON/OFF THE ORTHOMODE COMMAND FROM KEYBOARD.
(i) F8= F8 ( FUNCTION KEY ), SIMPLE PRESS THE FUNCTION KEY (F8) TO ON/OFF THE ORTHOMODE COMMAND. IF IN YOUR LAPTOP/PC                   SIMPLE PRESS F8 IS NOT WORKING THEN PRESS F8 WITH FN KEY (FN+F8).
            WHEN YOU PRESS THE KEY F8 OR FN+F8 THEN THERE IS IN THE COMMAND LINE A TYPE OF NOTIFICATION APPEARS THAT                       <ORTHO ON> OR <ORTHO OFF>. THIS IS NOTIFY US THAT THE ORTHOMODE IS ON OR OFF IN OUR AUTOCAD.
(ii) CTRL+L = IT'S THE SHORTCUT KEY FOR ON/OFF THE ORTHOMODE.
2.BY COMMAND:-BY COMMAND THE ORHTMODE IS ON /OFF IN A SIMPLE WAY
THERE IS ALSO TWO WAYS TO USE THE ORTHOMODE COMMAND TO ON/OFF
                             (i)  JUST TYPE "ORTHO" AND THEN PRESS ENTER. THEN THERE IS TWO OPTION APPERS ON AND OFF .
                                 TO ON THE ORTHOMODE JUST CLICK ON ON OPTION AND THEN PRESS ENTER "OR" TYPE ON IN COMMAND LINE
                             (ii) WHEN TYPE ORTHO IN COMMAND LINE THERE IS AN ANOTHER COMMAND APPEARS AS "ORTHOMODE"
                                 IF YOU CHOOSE THE ORTHOMODE COMMAND FROM THE COMMAND LINE TO ON/OFF THE ORTHOMODE OPTION
                               THEN THERE IS VALUE APPEARS AS 0(ZERO) AND 1(ONE). ZERO (0) MEANS THAT THE OPTION OF ORTHOMDE IS "OFF"
                              AND 1(ONE) MEANS THAT THE STATUS OF ORTHOMODE FOR ON/OFF IS ON.
                             IT MEANS IF YOU CHOOSE THE OPTION "ORTHOMODE" THEN SIMPLY TYPE 0 (ZERO) FOR OFF THE ORTHOMODE THEN
                             PRESS ENTER. AND TYPE 1 FOR ON THE ORTHOMODE .
3. BY CLICK ON ICON:- IN THE STATUS BAR OR OPTION BAR ( WHICH IS AVAILABE IN THE BOTTOMOF THE AUTOCAD INTERFACE DISPLAY) THERE IS THE ICON OF ORTHOMODE BY SIMPLE CLICK ON THE ICON OF ORTHOMODE TO ON/OFF THE ORTHOMODE OPTION
IN THE DESCRIPTION TWO IMAGES ARE ATTACHED IN THE FIRST IMAGE THE CONDITION IS "ORTHOMODE OFF"
AND IN THE SECOND IMAGE THE CONDITION IS "ORTHOMODE ON"
Etiquetas (1)
jayhar
en respuesta a: Anonymous
Make it Articles in your profile
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Etiquetas (1)
