- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Drawing Scales added automatically to template drawing
Hello all
I have a dwt drawing for our structural designers with a small number of drawing scales imbedded on the template, and on 10 out of 12 installations every time you start a new drawing from that dwt the scales shown on "Template as it should.jpg" shown below are the ones available as it should be. ![]()
The problem happens only on 2 machines that every time you start a drawing from the same dwt there are a series of scales automatically added and altered to that drawing before you start anything, as shown below on "Added to Template file.jpg".
What is going on with these 2 machines?
I have noticed that on the 2 problematic machines the Edit Drawing Scales window show a different description of the scales (note the highlight 1:5 on both attachments are 1 paper unit=5 drawing units and the wrong one shows 1 paper unit=0.005 Meters).![]()
I would like to believe this is something related to a system variable but can't find anything on my research. How can the same dwt file behave differently on different machines? ![]()
I would appreciate any clues from the clever people on this forum.
CheersAdded to template file
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Impossible if you talk about command NEW or QNEW. But we see two different issues.
a) 1:5 for example is different
b) there are more scales.. and the name indicate that there was an "insert"-workstep.
Are you really really REALLY sure you take this one DWT file and not an edited copy?
Please OPEN the dwt file (command open, extension = dwt, select your template file),
how is it now?
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
how is it now?
Thanks for your reply CADffm.
I am talking about QNEW and am sure they are all opening the same file set as the default template file for QNEW, that is sitting on a read only network location.
If there was an -insert it is done on the background before I can start using the file, I have checked ACAD.LSP, APPLOAD and ACADDOC.LSP for any anomalies but could not find anything.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I think we do not talk about plain Autocad, or?
Perhaps Architecture, Civil3D or another vertical product?
Please compare the versions in ABOUT dialog.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
...or some automatic executed code from a plugin inserting a block (titleblock, or layout, ...)?
I agree with that statement:
if you save as drawing as template, that does not contain any "xxxx_1" scales .. and you later start with command _NEW with exact that dwt-file then it also should not have any of these scales.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-8E54B6EC-5B52-4F62-B7FC-0D4E1EDF093A
Try it in safemode..still happens? Please upload one screenshot of your ABOUT Dialog, thx.
Sebastian
