cadffm
en respuesta a: Anonymous
When all Layers are thawed, command SELECT, option ALL,
You will see the counting of ALL top-level objects in your DWG (all spaces)
Or for only the current space also possible:
When the number of objects fewer then your PROPOBJLIMIT (max.32767)  you can see the count in your properties palette (CTRL+1)
If there are more objecs and you have full version of AutoCAD, use this "command" (sslength(ssget "_X")).
In both versions, Full&LT also possible after selection by CTRL+A: Start command MOVE or Copy or similar,
you can cancel the command then, the answer is written in commandline [F2]
______
Sebastian
