wispoxy
en respuesta a: agajardoc
Issue:While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:Fatal errors can have a variety of causes.  They often indicate a corrupt drawing, a program corruption,  or a problem with your system configuration.
Solution:There are several ways to troubleshoot the problem:
If all the above solutions fail, you may need to ask the Community forum or contact Autodesk Customer Support.
