531 Vistas, 10 Respuestas
Options error
Everytime when I open the options _Op i get error window which force me to modify on the value numbers of Rendered object smoothness, Number of seconds before display and Number of seconds to delay. This happens every single time when i open options.
jayhar
en respuesta a: Anonymous
Change Number of seconds before display and number of seconds to delay as shown message
or
Reset to defaults settings in profile
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
en respuesta a: jayhar
Hi.
It does not help when i change the numbers. When i do it and i need to open again the options i get the same message. It won't me to modify anything til I put som random numbers of seconds before display and number of seconds to delay. I have reinstalled AutoCAD but it does not help also.
Yousef
Alfred.NESWADBA
try the reset settings to default as suggested (>>>details<<<).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
jayhar
When accessing the Options dialog in an AutoCAD product, a message appears stating
Let see this
en respuesta a: Alfred.NESWADBA
Hi.
I did reset settings to default but nothing changed. The same error shows again.
Yousef
Alfred.NESWADBA
@jayhar
Please find the difference between the users screenshot content and the suggested links.
The screenshot from TO shows "from 0,01 to 10,00" ... the suggestion about ROLLOVERTIPS as well as the link you showed states "from 0,00 to 10,00" ... that's a small difference, but I guess an important hint that the error messages point to a different variable!
- alfred -
Alfred NESWADBA
Hi Jayhar.
I did that. It does not help me.
Yousef
Alfred.NESWADBA
Same error when you have opened your file or when you started with an original AutoCAD template when you started _OPTIONS?
Can you please create a new Windows user account, login with that account, start AutoCAD, start a new drawing (not any of yours) and run command _OPTIONS, does that work?
- alfred -
Alfred NESWADBA
Hi.
It does work when i create a new Windows user account. What should I do with my original Windows account ?
Yousef
Alfred.NESWADBA
Then reset settings to default should have helped.
Maybe you can follow the manual way to reset as described in the lower part of the AKN article >>>click<<<.
Alternative could be to login with this new account, save AutoCAD settings, login back to the original user account and restore settings. Please find the AKN article for export and import settings >>>here<<<.
- alfred -
Alfred NESWADBA
