pendean
en respuesta a: Anonymous
Open 2018: open a file, pan around, save and close the file. Close 2018. DWG filetype is now associated with R2018 in WIndows unless you've set up WIndows Explorer to use an exe other than ACLAUNCHER.EXE (or AutoCAD DWG LAUNCHER) to open the file (not any variant of acad.exe like you did already).
If you open R2016, Windows will always use this always moving forward until you repeat the above.
Read all about it here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/DWG-file...
Hope that helps.
