RobDraw
en respuesta a: ChicagoLooper
@ChicagoLooper wrote:
The answer: No, it wouldn't make sense to merely change units and CS, at least not to me because there would be no way to verify accurate position, scale and rotation after the changes are made, whereas with the ALIGN command, I could.
So, I, as a user that realizes the civil world is a world and not a project, doing this for the first time would question any workflow that could not be verified after execution.
How do I verify the results after using the ALIGN command and why couldn't that same verification process be applied to any other methodology of fixing those broken files? Furthermore, if having the georeference a requirement of the project, why isn't an accurate version of the civil file available?
Rob
