- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Yes, absolutely. I agree about the units but I have found many times, too often in fact, where the coordinate system wasn't honored and the drawn line work was physically moved closer to the origin because the user was either uncomfortable, inexperienced, or both, working so far away from 0,0. Plus, with many fingerprints on a drawing, a user may rotate the drawing so it's easier-to-read or to make-it-a-better-fit when viewed through the viewport. These actions cannot be resolved by simply changing the units, due to the GeoRef being broken. I will always defer to a known coordinate system and unit adjustment vs. the align command but doing so may not always be possible.
As it is, this OP is in plain vanilla AutoCAD and not in the C3D or M3D forum so speaking about coordinates may not be applicable to his or her workflow when compared to the workflow typically found in Civil or Map. Even if the coordinates are shown in mtext notes within the drawing, we still don't know whether orientation has been maintained or rotated. All we know is the object, such as a benchmark, building corner, manhole cover, etc, has coordinates that are not consistent with what's displayed in the properties palette.
In the absence of the original drawing file (most likely created by someone with an understanding of coordinate geometry i.e. surveyor, GIS analyst, cartographer, ship navigator, etc.) the align command, or something similar, must be utilized to re-georeference it. This entails 1) re-positioning, 2) rescaling, and 3) rotating. Make no mistake, you need all three. Sometimes rescaling and rotating will have no effect because it already has the correct scale and rotation but performing all three anyway will insure proper alignment. Re-georefing must be done using at least two known points, such as two benchmarks with known coordinates, but using more than two would invariably improve accuracy and the align command is capable of using more than two even though many users only use the minimum.
Regarding known coordinates in the drawing, if you're lucky, they are x- and y-projections measured in units of feet or meters. If the coordinates are not projected but are geographic, then the coordinates are latitude/longitude and are in units of degrees. Would you, and everyone else in your firm, feel confident locating lat/long benchmarks in your drawing when everything else, i.e. buildings, roads, infrastructure, etc. is drawn using feet or meters?
Chicagolooper
