beyoungjr
en respuesta a: richardmorris1969
When using the Align command just be careful not to scale the result, you will see the prompt for scaling as Y/N.
Also, If you know which direction true north is in the provided plan then the simplest Align method would be to create a 90 degree line in AutoCAD starting at your known coordinate point and proceeding any length at all (90 degrees being true north in ACAD).
Using the 2 known point of your source objects you can select the first source point, then first target point (start of 90 degree line), then second source point, then second target point (length not important at all).  You will then be prompted for scaling Y/N before the alignment is applied.  The length can be as short as a centimeter or as long as 200 kilometers because you will not be scaling.
BTW... Please ensure you are working in the WCS before this.  Should be unless you have been playing around with coordinate systems.
Hope this helps,
Blaine
Blaine Young
Senior Engineering Technician, US Army
