Thank you guys I will try and use the align tool and then check back using known physical features.
The drawings are accurately drawn within 5mm which I believe will be ok for this type of construction.
The designer is referring to WGS84 system
I dont have two points just the corners of the building i think i will create two points in the position i require and then move / align the building to them
So for example if i had a square of 10m x 10m and one corner was noted as being at coords E 10 N10 and another corner at E10 N20 but were in an arbitrary position.
I propose to create one point at E10N10 and another at E10 N20 and move drag align the relevant corners of the building to those points.
What do you think?
