09-11-2018
05:04 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-11-2018
05:04 PM
Unfortunately the "block of houses" you received from the designer is "not set to these coordinates just noted with them" raises some big issues and I'm not sure you fully understand the implications of those issues. If, and only if, the designer's drawing conforms to the following conditions:
- The houses are accurately drawn without any doubt regarding their positions relative to one another.
- The designer used a known 'projected' coordinate system and not a 'geographic' coordinate system (the former uses x/y coordinates with units in feet or meters while the latter uses latitude/longitude coordinates in units of degrees).
- You have at least two georeferenced points and their coordinates. Without their coordinates the points are useless.
I'm curious as to what the national grid is and how the designer described it.
Chicagolooper
