richardmorris1969
32018 Vistas, 15 Respuestas
Move Objects to Specific Coordinates
Hi
I havve an object (a block of houses issued by a designer including dimensions and national grid coordinates of certain points noted. This drawing is not set to these coordinates just noted with them
How do I move the object / drawing to the noted coordinates in order that I can then use it in my survey instrument to set out the building on site.
i think i know how to move it all as a single object and get one point correct but it really requires two points on the object to be moved so that the drawing / object is at correct coordinates and correctly aligned.
Does that make sense?
Thanks in advance all
Etiquetas (2)
