09-09-2018
12:53 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-09-2018
12:53 AM
>> I want to know what's the reason behind this issue......
Some input:
- Could be Intel I3 ... if you have other applications rounding (also background services)
- Could be 2GB as that is really to few memory
- Could be your graphic card
- Could be the complexity of your dwg-file(s)
To say it is "that one reason" is not possible without knowing more details, starting with the description when the "hangoff problem" arises. But your hardware does not fit to AutoCAD 2017 minimum requirements (assuming you are on 64bit os) >>>click<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
