260 Vistas, 2 Respuestas
Faces hang problem in autocad 2017 version
Hello sir,
I usually using i3 intel processor with 2 gb ram lenovo laptop facing hangoff problem while operating autocad 2017
That means not working properly
I want to know what's the reason behind this issue......
Thankyou
Alfred.NESWADBA
en respuesta a: Anonymous
Some input:
  • Could be Intel I3 ... if you have other applications rounding (also background services)
  • Could be 2GB as that is really to few memory
  • Could be your graphic card
  • Could be the complexity of your dwg-file(s)
To say it is "that one reason" is not possible without knowing more details, starting with the description when the "hangoff problem" arises. But your hardware does not fit to AutoCAD 2017 minimum requirements (assuming you are on 64bit os) >>>click<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
Your system only meets the minimum requirements on a 32bit Windows laptop: it fails for the minimum on a 64bit system.
i3 is for web surfing, not AutoCAD use.
Minimum means very very slow, sometime so slow it appears to hang.
