- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
unhandled access violation writing 0x0000 exception at fd2cbb61h
Please your help
unhandled access violation exception 0x0000 writing at fd2cbb61h
any solution
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
welcome @Anonymous.autodesk.com!
When does that error appear? What are your system info's (operating system, graphic card + driver), what product do you have (which AutoCAD version and/or vertical and servicepack).
As I'm not sure to have seen a writing exception like you wrote from AutoCAD itself can you create a screenshot and upload that screenshot from the error info?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Try opening another drawing.
If you can open another drawing, the original drawing may be corrupt and require repair.
See: How to repair corrupt AutoCAD files
- Uninstall any antivirus or desktop locking programs.
These programs can cause errors in AutoCAD, since they prevent the system environment from working. Reset AutoCAD to defaults.
See: How to reset AutoCAD to defaultsTurn off Hardware Acceleration.
See: Starting AutoCAD-based products without hardware video accelerationUpdate your graphics driver.
Install the latest graphics driver from your video card manufacturer or use an AutoCAD-certified driver.
See: How to update your system to the latest certified video driverTry logging in under a new Administrator Windows Account.
If you create a new account and can successfully open the drawing, you can either use that account or rebuild the user profile in Windows.
See: How to create a new local administrator Windows user account- If DisplayLink Core software is installed on your system, try uninstalling it.
- Do a full uninstall and reinstall of AutoCAD.
See: Remove All Products from a Windows System Uninstall and reinstall the .NET Framework.
See: How to remove and reinstall the Microsoft .NET FrameworkUninstall and reinstall Visual C++.
See: How to remove and reinstall Microsoft Visual C++ Runtime LibrariesClear the digital signature icons and then uninstall and reinstall the application.
See: FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 4048b9h
If all the above solutions fail, you may need to ask the Community forum or contact Autodesk Customer Support.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi
The fatal error happened:Unhandled Access Violation Writing 0x0000 Exception at 5181e3d6h
When i want to open JC ,the error appear.,see the following screenshot. WIN10
Please your help. THANKS.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
So that happens only with one specific drawing?
Start AutoCAD (just an empty drawing), run command _RECOVERALL and select this drawing and see if there are errors (which hopefully get cleaned).
As you are using Windows 10 make sure you have installed AutoCAD 2016 SP1 >>>click<<< as this seems to have some issues solved that might happen with Windows 10.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi
I opened not a drawing, it's a short-cut icon JC, Only when i open it , that error appear. but when i open a drawing, it's ok,
thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Ok, thank's for clarifying that.
If you first use Windows explorer to go into that linked folder and double click then a DWG inside that folder ... can that be opened then?
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
