789 Vistas, 7 Respuestas
Polyline linetype
I have a problem with polyline. It has dashed linetype but some of its segments visualize in a wrong way - as continuous. The linetype scale is right as you can see on the picture. If I hoover over the polyline, I can see the preview of completly dashed line.
In paper space it looks the same way, only when I zoom really a lot regen all I can see the line is correct.
 Please help, it's really confusing.
Jana
Etiquetas (2)
pendean
en respuesta a: Anonymous
Post that DWG file and remind everyone what variant and year-version of AutoCAD you are using please.
cadffm
Are you sure your segments are long enough for a linetype pattern, or is the polyline set to generates linetypes(last property in palette)
Sebastian
en respuesta a: pendean
Thank you for your quinck reply, here is the dwg file. I'm using Autocad 2018. version: O.49.0.0 on win 10, Intel core i7/4770S, 16GB ram.
en respuesta a: cadffm
I tried already both linetype generation on and off and I have changed only when I hoovered over it, in the preview. segments are long enough, even if i change linetype scale of the polyline it is not getting better.
cadffm
Your polyline and setting looks fine, Did you test that with exactly the provided file, just open the file and it looks like your picture?
command: 3Dconfig
Set HardwareAcceleration on or off changes nothing ?
command REGEN ?
2DRETAINMODE=0 ? (only for testing)
Sebastian
Helped turning off the hardware acceleration!
REGEN and 2DRETAINMODE=0 did nothing.
And yes, I had problem with exactly that file. Could you please explain me in a simple way (if it is possible) what is the difference between hardware acceleration on and off? I have to say, that I had already problem with construction lines when HA was on.  So I don't know if it is usefull to keep it on...
Thank you a lot for your help!
cadffm
"in a simple way (if it is possible) what is the difference between hardware acceleration on and off? "
https://en.wikipedia.org/wiki/Hardware_acceleration
Your graphic-driver is not the right or not uptpdate,
or/and
your Settings are not set properly
or/and
your graphic card/chipset (or there drivers)  only partially support the required functions for AutoCAD.
Sebastian
