09-02-2018
08:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-02-2018
08:20 AM
HI,
>> I was just wondering why they dip so low in the first place.
Also a pointcloud can have negative elevations. In such cases an insert at 0,0,0 shows points lower than Z=0
>> I have cropped them a lot
Well, that describes the display, thanks for clarification!
>> I wonder if it is has something to do with the Z axis Origin in ReCap?
Not really, by default AutoCAD works with the same Z-orientation as ReCap.
But if you think the pointcloud is rotated in AutoCAD you can use ROTATE3D (or 3DROTATE) to reorient the pointcloud.
You might also look to the import of your native pointcloud data into ReCap.
From your previous screenshot I can't identify if the pointcloud is oriented well or not.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
