en respuesta a: pendean
Hi pendean.  I read the solution you posted but based on instructions in the Longbow link, it requires the Longbow Conversion Tool be installed first.  I've read various reviews on this tool and found it to be costly and may not be 100% reliable.  The update I found previously was a true AutoCAD patch without the need for Longbow's Conversion Tool.  Perhaps you can verify whether or not this Longbow tool is required when installing the patch they've linked.  If it is a genuine AutoCAD patch and Longbow isn't required as per their instructions, then your suggestion is the most expedient method of solving the problem.  If you're unable to compare the hash at this time, when I return to the office I can run a comparison of both the Longbow and AutoCAD's version to verify whether or not they are the same patch.
