2084 Vistas, 2 Respuestas
xref includes other xrefs
I'm trying to attach a file as xref  in my drawing but that file includes some other xrefs. How can I attach that file in my drawing, not including the other xrefs?
Etiquetas (2)
Alfred.NESWADBA
en respuesta a: Anonymous
what you'd like to have is the XREF-type "Overlay" instead of the default "Attachment".
E.g. if you have a circle in 01.DWG, then you create a rectangle in 02.DWG and insert the 01.DWG as overlayed XRef.
Now when you create a new drawing and use XRef to insert the 02.dwg you won't see the circle.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
Thanks :cara_con_una_leve_sonrisa:
