- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> I actually think its a setting?
If it's drawing dependent then it's a drawing internal setting.
>> when i go to offset and drag the cursor down a fine dotted
>> line shows up in the direction I'm moving
Please be more specific! "when I go to offset" ... is not specific enough, I guess you already have started the offset command, then AutoCAD asked you to specify an offset distance, again I guess you already have used the left mouse click to start to show the distance and now you get a drag-line visible (an orange dashed line) ... is that correct? You are asked for a second point (so AutoCAD can calculate the distance between point 1 and point 2) ... what did you do now?
Or is it all done in another way? If so .. what EXACTLY did you do?
And again, if it's drawing dependent it could help a lot if you show us your dwg-file.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
