en respuesta a: Anonymous
Hi after i type in the offset(200mm) it says " select object to offset or [exit undo] <exit>
When i select the line and move cursor down it say's "Specify point on side to offset or [exit multiple undo] <exit> BUT the line doesn't move stays blue then turns white when i click mouse.
Works fine in the other drawing window ???
