08-24-2018
12:13 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-24-2018
12:13 AM
In my first example above (#10) I used "Extrude a region along path".
Here now I followed the suggestion of @john.vellek. I also used an approximated path but with an higher accuracy (a 200 points spline). Then two sweepings using the Basepoint option. (Sweep -> select one of the rail profiles -> Choose for basepont the startpoint of the path -> select path -> ready. And this again with the other profile).
Both variants give a (IMHO) suitable result.
The main problem sees to be your 3D-Poly-Path with about 8600 segments. Maybe this is too much for a "Standard" computer.
cadder
Jürgen Palme
