j.palmeL29YX
en respuesta a: ian.mag
And what about the solution suggestion given in posting #10 (https://forums.autodesk.com/t5/autocad-forum/sweeping-along-3d-polyline-in-autocad/m-p/8219918#M9460...) ?
Of course you can refine the approximated new path using 100 points or 200 points to get a closer result.
BTW: At this point I must ask you: What is this model useful for, what do you need ist for?
Last night I tried to create a model using the given path (3D-Polyline). After more than 12 hours AutoCAD still worked, but not ready yet. I decided to abort (I need my computer for other work) - but If you have enough patience ...
cadder
Jürgen Palme
