en respuesta a: Anonymous
It sure sounds like a graphics card issue.
You can see all the Nvidia cards that are certified to work with AutoCAD here:
https://knowledge.autodesk.com/certified-graphics-hardware
I don't see GTX as any of the options for Windows 7 through 10.
Type the command 3dConfig
and then turn off Hardware acceleration to see if that helps.
Also I would replace your 7200rpm hard drive with a solid state drive.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
