- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @j.palmeL29YX,
I agree that copying the path would not adjust the radius. I merely wanted to show the process using a basepoint (and that the basepoint does not need to be on the profile itself) and then a path selection. I noticed when opening the file that it had proxy objects so I decided to also run an EXPORTTOAUTOCAD. I am re-doing this along the central path (and I will try to be patient) and hope to post my results when it finishes.
[Edit] I have found that applying a SPLINE Fit to the 3D polyline seems to help. I was actually able to get a short section of the rails to sweep based on the red pline but it is a painfully slow process on my laptop.
This is the result when I take a short section of the path and apply the two regions in my sweep:
John Vellek
