338 Vistas, 4 Respuestas
autocad is laging
sir i recently bought alien ware 15 r3 with i7 7th gen, 16gb ram, gtx 1070 graphics, Installed it on my 7200rpm sata harddrive but I am getting lag in mouse cursor and take time to open. what i can do for it
pendean
en respuesta a: Anonymous
Your AutoCAd year version is...?
Your Windows OS is...?
Also pot a screenshot of your GRAPHICSCONFIG command pop-op please.
en respuesta a: pendean
autocad version -2019
windows os - windows 10 home
It sure sounds like a graphics card issue.
You can see all the Nvidia cards that are certified to work with AutoCAD here:
https://knowledge.autodesk.com/certified-graphics-hardware
I don't see GTX as any of the options for Windows 7 through 10.
Type the command 3dConfig
and then turn off Hardware acceleration to see if that helps.
Also I would replace your 7200rpm hard drive with a solid state drive.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
cadffm
in every file, even new files, with little content?
if not, upload an example.dwg
and an ScreenCast if possible.
Sebastian
