Karol-Or
502 Vistas, 6 Respuestas
Extract Intersections creates red lines instead of bylayer color
Which system variable controls the color of the new created intersection line?
In the Color command it is bylayer, but despite of that the intersection lines are always red
Alfred.NESWADBA
en respuesta a: Karol-Or
please help me out ... what command is used for "Extract Intersections"?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Karol-Or
en respuesta a: Alfred.NESWADBA
Interfere
Alfred.NESWADBA
thank you for clarification, is that what you are looking for?
Start command _INTERFERE and then use option _SETTINGS
- alfred -
Alfred NESWADBA
Karol-Or
In my 2013 version there is no Settings option on this command
Alfred.NESWADBA
The helpfile for AutoCAD 2013 tells me something different >>>click<<<
Does a systemvariable INTERFERECOLOR exist >>>click<<<?
If so set it to your color ...
- alfred -
Alfred NESWADBA
Alfred.NESWADBA
just to make sure ... you have started _INTERFERE (with leading underline) and not -INTERFERE (with a leading dash)?
- alfred -
Alfred NESWADBA
