- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Issue with Sweep function
Hello!
I am trying to make cornices for a building, but I can not sweep cornice shape along building perimeter path. It gives error codes 108028 and 84026. I have been looking for a solution for a long time, but I can not find one. When I am trying to sweep a cornice shape (made of some smaller parts) along the path it leaves some (randomly chosen) cornice parts behind with error codes. If I am trying to sweep these cornices on some other path it works well most of the times. I also made some random path that looks similar to the building perimeter and it has similar issue on it aswell.
I sliced up the cornice, because it has different colors on each side and it would be easier to render it afterwards. However if I draw only outlines of these cornices and try to sweep them, it still does not work.
I also made a screencast and attached my AutoCad file so you could see the issue yourself.
Mattias
