- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Been working with hatch and layer transparency fairly frequently. Never had a problem with this feature working until today. Doing a revision to an existing drawing and after plotting I noticed the 50% transparent layer was plotting too dark. I checked the page setup, and "Plot Transparency" was checked. Transparency Display is 'On', so I see the transparent layer in the viewport. I went back to my original drawing to make sure I wasn't seeing things, and sure enough the plot from 2 weeks ago showed the transparent layer at 50%. Today I cannot get the same .dwg file to plot properly. Anybody have a clue what my fat fingers pressed by accident this time...lol?
Alan
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
All: Make sure this variable is set to 1 (or two)
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-38F03A2C-6D36-4AD9-BBE0-9CA574BEF218
A part:
Memory issue / driver problem.
Workaround is going dwg -> pdf -> paper
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
wow...excellent help, thank you! I think you nailed it...must be a memory or driver issue. I used batch plot to plot to pdf in autocad. The transparency did not show up there (screen shot of today's plot). But then I printed that pdf to another pdf, and the transparency showed up perfectly there. How strange. I will update my driver and have a known memory issue, which now needs to be dealt with immediately. Thanks again.
