andrew.wheaton
577 Vistas, 4 Respuestas
Attribute text not displaying
Good afternoon.
I am creating a block for a large setting out job and I cannot make the attribute text show.
I have created a block with attributed text and the text only shows when I edit the block.
Can anyone help me?
The block need to be called SOP.
andrew.wheaton
en respuesta a: andrew.wheaton
I have solved the attribute display issue.
I now cant seem to get the attribute to update in line with the attached sample of setting out information.
Can anyone help?
john.vellek
Hi @andrew.wheaton,
I redefined your block with a new attribute and it seems to be working properly. Please give it a try.
John Vellek
Can you describe what happens instead?
What does your command-line show when you start the script?
2 settings necessary to get that working:
  • ATTREQ = 1
  • ATTDIA = 0
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @andrew.wheaton,
Try setting ATTDIA=0 when you try to create the points.
John Vellek
