1496 Vistas, 2 Respuestas
Problem with hatches autocad 2019
Just downloaded autocad LT 2019 and are having problems with hatches made in previous autocad versions
Attached file is from Autocad  2016.
Strange lines appears over the screen from the old hatches
jayhar
en respuesta a: Anonymous
Can you please upload AutoCAD file 2013 format.
1, Is it lines, use command "GRAPHICSCONFIG" turn off.
2, Is it hatch, may be end points didn't joint. or you can try "HATCHEDIT" select remove boundary.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
pendean
Turn off the variables LINSMOOTHING and LINEFADING and see if your video card stops choking under LT2019's demands.
This would be a good time for you to get updated video card drivers for it as well in WIndows Control Panel's Device Manager: if you don't know how to do that just ask.
