07-31-2018
04:37 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-31-2018
04:37 PM
Addition to Scot's comment, I guess your coworker has other codes running without testing your LSP.
Probably (= ds nil) is a false statement on his end.
If this is the case, replace this
(if (= ds nil)
(setq ds 999)
)with this
(setq ds 999)
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
