- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I'm taking sections of a Point Cloud to then draw on a polyline to get a profile. My thought is to draw a couple and do a simple loft or sweep command to joint the sections, creating a tunnel.
I keep getting this error though 'Cannot sweep or extrude non-planar objects', even when I manually set my UCS to the face of the polyline object I have just drawn.
Any help?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
All the vertices of the polyline must have the same "Z" number with respect to the current UCS for extrude to work. If just one is off by a miniscule amount its a no go.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
.. even when I manually set my UCS to the face of the polyline object I have just drawn.
Any help?
Set the UCS before drawing anything.
If you still need help - delete everything except for you drawn lines/arcs and attach the file here.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Your profiles should be planar (no z component), so yes, each UCS defines the plane onto which you want to draw your profile.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Got the same problem when trying to extrude closed polyline with 4 vertices and two curved sides, all vertices on Z is 0 (elevation for all vertices set to 0) but getting same error "Cannot sweep or extrude non-planar objects".
I found the following solution - convert closed polyline to Region and than extrude.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
