- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@76jsa wrote:
.… is there a way to set ROTATE by reference as default, not by base point? ….
You're not going to escape the need for a base point, in any case, since Rotating by Reference is still necessarily around some base point. But you could define a dedicated command that automatically feeds in the Reference option after that. Something like this [minimally tested]:
(defun C:ROTATER (/ ss) ; = Rotate with built-in Reference option
(if (setq ss (ssget))
(command "_.rotate" ss "" pause "_reference")
You could even UNDEFINE the native ROTATE command, and make that the definition of that command name by taking the R off the end of the name. You would still have standard ROTATE available if needed, by typing it in with the period prefix:
.ROTATE
