en respuesta a: john.vellek
hello @Anonymous,
plotting to pdf, plot in background is on. The server is in Pittsburgh and i am working with the SSM in Jacksonville Fl. , so I am sure the latency ping is part of it. So what amount of sheets are to large to deal with given that , i assume over 200? I finally got the dwg layouts loaded and did a couple of batch plots using SSM, and it was faster, by about 1/2 the amount of time it takes me to open up (6) 50 sheet .dsd files and print those. Takes 4 hours to process the files with Batch plot and 2 hours through Sheet Set Manager. While the SSM was quicker, it did seem to slow autocad with plotting in background, autocad would hesitate every other 10 commands or so.
