76jsa
4145 Vistas, 9 Respuestas
ROTATE by reference as default
is there a way to set ROTATE by reference as default, not by base point?
SEANT61
en respuesta a: 76jsa
You may be able to redefine the command to call some addin program.
Alternatively -
For a rotate with reference call, I use a Right-Click menu entry with the command macro:
^C^C_Select \_rotate previous ;\r @;
May your cursor always snap to the location intended.
Kent1Cooper
@76jsa wrote:
.… is there a way to set ROTATE by reference as default, not by base point? ….
You're not going to escape the need for a base point, in any case, since Rotating by Reference is still necessarily around some base point.  But you could define a dedicated command that automatically feeds in the Reference option after that.  Something like this [minimally tested]:
(defun C:ROTATER (/ ss) ; = Rotate with built-in Reference option
  (if (setq ss (ssget))
    (command "_.rotate" ss "" pause "_reference")
You could  even UNDEFINE the native ROTATE command, and make that the definition of that command name by taking the R off the end of the name.  You would still have standard ROTATE available if needed, by typing it in with the period prefix:
.ROTATE
Kent Cooper, AIA
scot-65
I have a similar utility to Kent's and have named it
c:RTR
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
SEANT61
en respuesta a: SEANT61
As a supplement to my Rotate by Reference command macro suggestion, here is a screencast of that, plus another By Reference sub option.  There are times when that sub option functionality comes in handy.  That sub-option macro:
^C^C_Select;\_rotate previous;;\r;@;\p;\\
pl.fischer68
en respuesta a: Kent1Cooper
how do you define this command ?
Kent1Cooper
en respuesta a: pl.fischer68
Copy the code and paste it into a plain-text editor such as Notepad.  Save it to a file [call it whatever you want] with a .lsp filetype ending.  In an AutoCAD drawing, use APPLOAD, navigate to where you put that file, and Load it.  The command name is ROTATER [not case-sensitive].
Kent Cooper, AIA
pl.fischer68
thank you so much dude, this rotate command was driving me crazy. Now the ROTATER does work, but it doesn't appear in the aliasedit panel (i'd like to create a shortcut for the new rotater command)
Kent1Cooper
.... (i'd like to create a shortcut for the new rotater command)
I think the command alias editor may work only with actual AutoCAD command names.  But you can make the name of the command anything you want -- the part immediately following  (defun C:  is always the command name, so just change ROTATER to something else [as long as it doesn't conflict with some already-existing command name or alias].
Kent Cooper, AIA
pl.fischer68
amazing ! thank you for taking the time to explain me this, hope it will help others !
