en respuesta a: john.vellek
Thank you for all of the suggestions.
The PROPERTIES command identifies these red square objects as "Hatch".
DDPTYPE says points are displayed as points (upper left selection in Point Style box).
The QSELECT command was able to select all of the red squares, and I could delete them, although I have to make sure there are no legal HATCH objects with the same parameters in my drawing that I don't want to delete.
I have attached a sample file that has the red square problem. The red squares do not appear when I open this drawing in AutoCad 2015, but they do appear when I open this drawing in AutoCad 2018.
