john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
It sounds like these red boxes are points.  DDPTYPE will show you some display types for points.  A value of 65 will show the points as squares.
A value of 1 should make them disappear.  You can also use a Qselect to pick them all and then delete them.
If you select one of the squares and then look at properties, what type of object does it identify it as?
John Vellek
