john.vellek
en respuesta a: Anonymous
HI @Anonymous,
This sounds like a fairly large sheet set. How are you Publishing the set to PDF? Can you share the settings?  Do you have plot in background turned on or off?
This slowness issue actually sounds  more like a latency issue with the server.  If you (as a test) move the files locally how does this behave?
John Vellek
