07-29-2018
08:04 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-29-2018
08:04 PM
Yes, @neaton's offer is a good hint.
Here is mine.
Before pasting, you may have to ensure what is the scale factor comparing between the source drawing and the target drawing. Then
- use "Ctrl + C" on the source drawing and
- "Ctrl + V" on the target drawing,
- type s immediately.
- enter the scale factor at the command prompt.
- you will be fine.
BTW this may be off the topic but hope it is a good practice in the future.
Drawing everything in model space with 1:1 scale all time.
For example, in model space draw a 10 unit length line for your 10mm line.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
