neaton
en respuesta a: Anonymous
You can't use the mirror command on the circles as they are currently drawn because the center points aren't aligned vertically. The lower circle quadrant points aren't at the same coordinate either and I assume they are supposed to be.
Accuracy is important when learning CAD so turn on your OSNAPs if you aren't using them. I have End, Midpoint, Center, Node and Quadrant on all the time. I don't use Near very often since it is random and usually not where I want my placement and Perpendicular may also be near a point when I really want a different snap point.
Misaligned quadrantsMisaligned quadrants
