07-28-2018
06:16 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-28-2018
06:16 AM
That's a curious situation. The resulting Arc will swing through a little more than 180 degrees, which I think is why Fillet won't put it in facing the way you want, even with a larger radius that would move it closer to where you want it.
FILLET as before, using increasingly larger radii [you may need to increase in very small increments] until you get the location relative to the two Circles where you want it. Then draw another ARC with the Center/Start/End option sequence, Osnapping to the Fillet-result Arc's center for the center of the new one, and its endpoints for the start and end. Erase the Fillet-result Arc.
Kent Cooper, AIA
